New thermo switch and thermostat, something is WRONG!
Old 04-24-2002 | 01:23 PM
Brian Wilson's Avatar
Brian Wilson
Post New thermo switch and thermostat, something is WRONG!
So, Mike and I replaced my thermo fan switch and my thermostat that I had bought from Pelican or Paragon? Anyway the thermostat is letting it run between the 2 and 3 hash mark and the fan doesn't kick on until the 3 mark.
Whats up???
Also, I hear all of this talk about fanS. I only have one. Is that normal?
Old 04-24-2002 | 01:32 PM
rplencne's Avatar
rplencne
Post
Does your european version have A/C ? If not, that's probably why there's no second fan.
-Bob P.
Old 04-24-2002 | 01:35 PM
jim968's Avatar
jim968
Post
Jonathan, since yours is a Euro model, does it have A/C? That might explain the single fan.
As far as the fan coming on late, maybe you've got either a defective new switch, or an inaccurate temp gage (factory gages aren't always accurate). Maybe try putting hte old switch back in & see what changes, if anything. Both my '88 na & the 968 have consistently run on or just above the second hash mark (one up from cold), with the fan coming on about 1/2 way to the next mark in traffic or on long upgrades.
Jim, wondering why they put Braille markings on the keys of drive-thru ATM's???
Old 04-24-2002 | 01:38 PM
TaboII's Avatar
TaboII
Lifetime Member
Post
Make sure you have blead the system fully then try ity again.
Old 04-24-2002 | 03:50 PM
Brian Wilson
Post
Pressure bled it with a real pressure bleeder! (I love my garage)
No AC=one fan problem solved
The old thermo would run right below the first line. The new one, well I said that.
Old 04-24-2002 | 04:58 PM
edd1em's Avatar
edd1em
Post
You have air in your system.
Quick Reply: New thermo switch and thermostat, something is WRONG!
