Ground scrubing
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
While making and installing the battery harness, I figured out a good way to scrub off the crossion on stud contact areas, such as the main neg to block.
A 3M sanding sponge. Cut out a little chunk with a hole drilled through for the stud. Just stick on, push down and twist back and forth.
Everyone on the battery kit will get one, but thought the rest of Rennlisters should know, no sense doing gluing sandpaper on sockets idea. It works great and only takes a few minutes to scrub clean. This is pretty tough stuff and can even be washed with your dirty rags and live a new life.
Regards, Tales from the front.
