The "Warped" Brake Disc and Other Myths of the Braking System
One question in my little foggy mind on the issue of not 'topping up' brake fluid occasionally....
If you didn't do it, what happens to your clutch hydraulics when your brake pads have worn down? Seems to me that you'd be at risk of sucking air into the clutch master cylinder as the fluid level dropped to compensate for worn pads... especially with four-pot calipers.
Jim, old, easily confused, and probably not clear on the whole concept...maybe.
Jim; The reservoir is separated into two sections, and I think you'll find that the clutch draws from the forward section, dedicated to the rear brakes and less likely to be drawn down with pad wear.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i've had to have big black's solid rotors and 993TT cross drilled rotors need to be turned
after driving hard in the high country of Colorado and Utah.
