Help diagnose a bump, bump, bump @<40 whrrrrrrr >40
I'm getting a bump, bump, bump, feels like the rear of the car, changes w/ wheel speed. At low speeds it feels like a flat spot on the tire, above 40-50 it sounds like tire noise or "knobby" tires, not so much a feel at those speeds as a sound. Doesn't change w/ acceleration, braking, reverse. I can’t get the symptoms when the car is on jack stands.
I changed my rear wheel bearings thinking it was that, no luck. I also repacked two CV joints on one side that had a cracked boot. The other CV shaft is relatively new, still w/ p/n sticker. Any ideas??? I did a lot of searching, that’s why I did the rear bearings but…
Thanks in advance listers,
Any other ideas? How accurate is “feels like it’s coming from the rear” in your collective experiences, could it be the front?
Edit: This happened after a DE weekend, on the way home about 5mi from the track.
Thanks,
I haven’t, but I’m thinking I could put the fronts on the rear and rears on the front and see if the bump, bump sounds/feels like it changed places…
Thanks,
Thanks,
And any "rear end" and "butt" jokes by the peanut gallery will be seen as pathetic, because I made it too damn easy.
Now this just going down hill. I was going to say I can definitely feel it in by butt...but I better not.
On a more relative note I think I found my problem. I believe I have a displaced belt in the right rear tire. I was going to swap the fronts to the rear, but I just looked at the tire closely and sure enough I have a lump, which is obviously more worn as well.
Time for some new tires...
Thanks,
Thanks,
