1987 944S OPRV oil leak
I just replaced the rubber o-ring and the aluminum seal ring on the OPRV and it still leaks a bit of oil. The OPRV is torqued to 33ft/lbs. any ideas?
thanks!
-martin
thanks!
-martin
I ran into a sealing problem on the turbo drain line which uses a banjo bolt that threads into the pan. I am pretty sure it came down to some small amount of dirt or junk that was preventing a good seal between the ring and the pan. My only suggestion would be to make sure all the sealing surfaces are as clean as you can possibly make them.
