40% LSD, what does it ACTUALLY mean?
I do know what an lsd is and how it works, but what does the percentage stand for. 40% or 100% what is the difference?
My guess is that a 40% lsd will allow 40% difference in wheel rotation before it start working. Ergo is a 40% lsd working sooner than a 100% lsd. Or am I wrong about that?
Eirik Kvello-Aune
<a href="http://www.diateam.no/porsche" target="_blank">www.diateam.no/porsche</a>
Eirik Kvello-Aune
I think it is 40% lockup.
Which I think means that lets say one wheel has traction and the other doesn't. The LSD will be able to give 40% of the power to the wheel that grips...I'm not really sure though.
Lifetime Member
Lifetime Member
LSDs used in racing can go as high as 80% or so. If you think of a fully locked differential as 100%, the 80% LSD only allows for a 20% difference between wheel speeds before they are "locked." This would not work on the street, but is OK for some tracks.
The typical true street LSD is about 40% like you say, and this allows for 60% slip.
Most LSDs can be adjusted by fitting different shims and/or clutch plates to change the lockup characteristics.
There is an excellent article about LSDs at:
<a href="http://members.aol.com/agspeed/LSD-lock.htm" target="_blank">http://members.aol.com/agspeed/LSD-lock.htm</a>
