Bleeding the slave
Old Jul 15, 2008 | 10:27 AM
Toran's Avatar
Toran
Originally Posted by kandyinmyvan
Where did you all buy your Motive bleeders other than online?
Got mine from Performance products.
http://www.automotion.com/productcat...cid=18&sid=293
Old Jul 15, 2008 | 06:16 PM
kandyinmyvan's Avatar
kandyinmyvan
Yea I just ended up ordering online. Should get here by Friday. That will give me enough time to scrub away two months of dirt and nastiness
Old Jul 16, 2008 | 12:17 AM
944-LT1's Avatar
944-LT1
A real fast/helpful way is to adjust the clutch pushrod all the out so that pedal travel is at most. Then adjust it back to norm before driving it. I just did mine by adjusting the pushrod so that barely two threads where on the fork....worked great!
Old Jul 16, 2008 | 01:56 AM
KuHL 951's Avatar
KuHL 951
Hey Man
Nice tip, it makes sense and I'll try that next time
Old Jul 16, 2008 | 06:00 AM
FRporscheman's Avatar
FRporscheman
Definitely a nice tip. I think this is a key point I have never thought about... and maybe why I always fail!
I got my Motive bleeder from paragon but I think I've seen it at harbor freight or some other store I was at recently. I want to get one of those bleeders that runs off an air compressor. I can't find one anywhere but we have one at work - a snap on - no need to spend for a $nap on on a simple tool like an air bleeder.
Old Jul 16, 2008 | 01:08 PM
CurtP's Avatar
CurtP
Remove the pressure gauge from your Motive and install a air hose fitting. Make sure you have a reliable pressure regulator (DO NOT use the cheap ones from Harbor Freight - they really suck) and set your pressure to 15psi. Done. I did this as soon as I pulled it out of the box. I've never manually pumped my Motive bleeder
Old Jul 16, 2008 | 01:45 PM
cegan09's Avatar
cegan09
OK, i have to do this later this week, and everything says to jack the rear end of the car. What is the purpose of this? I don't really have the means to jack up the rear end in its current state. Is it possible to do with the car level? sorry if this is a dumb question.
Old Jul 16, 2008 | 03:37 PM
FRporscheman
Jacking up the rear is supposed to raise the slave bleed nipple as high as it can go.
Old Jul 16, 2008 | 04:04 PM
cegan09's Avatar
cegan09
hmmmm, i see. Guess i'll have to work something out.
