BOV upgrade/replacement
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">I installed the Saab 9000T CBV just yesterday. Can't remember the Bosch part number right now but I can check it if necessary. Apparently it's almost the same as the 993TT valve, except just slighly meatier </font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Saab version should be better than 993 BOW.
Bosch #0 280 142 110 or Saab # 44 41 895,
Those Forges,Blizs etc. does usually not work any better than these Bosch valves. Get those shiny expensive ones if you are looking for that rice burner bling,bling look. For 35 euros iam satisfied with Bosch/Saab valve !
I run a Bailey Valve (to atmosphere) on my Probe, and a Forge (Bypass) on my Saab.
It is generally a bad idea to have a atmospheric valve after an air meter, even teh best valves will throw you off.
These Bosch units will last for years.This Forge valve is quite expensive (135$), for that price iam able to buy quite a lot Bosch/Saab valves....I just bought one for 35 euros. Installation will take couple of minutes.
For what its worth, I went through two of the OEM CBV's in three years before I bought the Forge. I am glad your experience has been different with them, and its true, they only take a moment to swap out, but its one less thing that I am worried about now.
Regards,
Regards,
Nickhance.
When my stock valve was failing at the track, I experienced loss of power and I could hear " chirpping " sound from the CBV. (a stock CBV should not make any chirpping noises)
I had a spare and all was well. Difference was significant enough to tell.
Eugene.
Eugene.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by nickhance:
<strong>Can you test the old BOV by taking it off and sucking on the vaccum line part of it?
It should hold a suction there, should it not?</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Yes Nick what you stated above is how to test it.
