Quick bent valve/cam question-Update bent valves identified!
Set to Full-Auto
Ok, after the t-belt broke I can barely turn the cams by hand, they DO NOT want to turn. Before I start pulling the cams and head, is it safe to assume that one or more of the valves are bent?
Set to Full-Auto
Well, I got impatient and started pulling the cams to get the head off. I've got the driven one off, but the one with the belt pulley has one bolt that won't come off. I'm afraid of stripping it out, but I need to get it off to finish removing the head. The bolts that are holding it on are the 6mm hex key kind. Any ideas?
Put the 6 mm allen on the bolt and hammer it down with a few quick hard hits to break the corrosion lose. Even stripped allens can be hammered down with 3/8 extension to reshape the hex recession. I have gotten most out without ever having to drill. It is not good to have metal shavings in the cam tower for the 8v heads.
Set to Full-Auto
I got the bolt off with a little more finesse, nothing broke or drilled. With the cams off I did a compression test and #2 had no pressure. The exhaust valve followers are a little depressed like they can't fully close, but the rest of the valves look normal from the top. Tonight I plan on pulling the head so I can begin repairs, does anyone have two "S" exhaust valves they want to part with?
