OT: 1991 Ford Probe help
I know, I know... Not a Porsche.
Ford Probe has ZERO electricity. The battery was replaced last week and the car ran fine for 4 days. One morning, no power. No interior lights, no nothing.
Jump start the car. It starts two minutes after being hooked up. Run the car for 5 minutes with the cables connected. The Probe shows "normal" on the battery gauge. As soon as I unhook the jumper cable the car dies. Again, no electricity at all.
What could it be? The car is old and has an old alarm with a kill switch on it. Any ideas would be appreciated.
Thank you!
Thank you!
it shows normal while the cables are on it because it is reading the other cars charging system. Take the battery out and have it tested, it may have a bad cell in it, if not then it is a charging problem. If you have another car with a good battery throw that one in for a test to see what the charging system does.
If you find that the new battery has a broken cell connector. Or a cooked cell. Make sure that your regulator is not overcharging the battery and cooking it. Your regulator should be apart of your alternator. take it off and have it tested.. I do not know your car. the regulator may NOT be apart of your alternator..HTH.
Sounds like a bad alternator. Maybe you can get it out to test it? For the 4 days that it was running, all the electric power was probably coming from the battery, until it finally died b/c of a lack of recharge. Just a thought.
