How do I take out driver seat belt?
I took the bolt out of the other belts, and they came right off. But the driver side seat belt has a wire running into it. How to I get the seat belt off?
I'm assuming you're referring to the coupler attached to the driver's seat? If so, the wire is just plugged into a plug under the seat. You can try reaching under the seat and disconnecting it, but you'll probably have to take the seat out. Could also just cut it... I'm pretty sure it's just to tell the car if you've buckled your seat belt, and I'm also pretty sure it's "fail" (i.e. cut) position is to assume you have.
