944/2 Manual Rack & Tie Rods Issue
Here it goes...
I purchased a manual rack complete with everything except the outer tie rods to put in my 1988 944. This rack is from an '86. I know that the later offset is different, but I am having strange issues regarding this. I measured my old rack from pin to pin at 54.5". When I measure my new rack WITHOUT outer tie-rods it is 50" from end to end. So I was going to use the method of threading my late PS tie rod ends onto the early MS tie rods, but the shortest I can make the pin to pin is 57", which is way too long. So, it seems that for some strange reason, I can use the early outside threaded tie rod ends and get the proper length, but I want to know why! Is my rack different? Are my inner tie rods different? Does my '88 actually have an early suspension on it for some reason? I just don't get it and everyone I talk to thinks I'm crazy. Any input is appreciated.
Thanks,
Justin Smith
Thanks,
Justin Smith
Thanks!
You do know that the tie rods are different between the manual racks and the power racks right? Early Offset Manual and Early Offset Power are two different lengths, same for Late Manual and Late Power. I am not sure off hand what the length difference is but I know it is there.
Almost Addicted
Interesting... This is getting so confusing. I wish the PET would explain and show more than it is. I need a giant spreadsheet of part #'s and application! I ordered the early tie-rod ends because even though this is an '88 with late arms, but a manual rack with early inner rods, all of the measurements keep coming up the same and they should work. I guess I'll find out on Wednesday. I still don't understand how they can be right, though!
I am going to have to call dibs on the threaded rod idea..
From 1/14/2006
If you look at the video close-up of the tie rod ends on these, they are male and the tie rods themselves are female. This means that you could get two short pieces of All Thread, 4 lock nuts and some power steering tie rod ends (female) and extend the length of these arms to be used with late offset.
Simple "Home Depot" mod that would work well for a rack like this.
Almost Addicted
you are correct in that it makes no sense at all why an early offset set up would work- they are VERY different lengths, like several inches.
Almost Addicted
