FS 944 cubby hole gauge cluster set 85.5+ 3 gauges---SOLD!
Campeck Rulez
I didn't want to put this on ebay because I made it specifically for my 944 and It would fit right in another 944.
Its a 3 gauge holder that I modified to fit in the cubby hole of 85.5+ 944's. The vacuum gauge has the fittings on it which let you just slip a vacuum line right over it. the air/fuel you just hook the purple wire up to the O2 sensor wire in the engine bay (plus +12 and ground). and the oil one you give it +12, ground, and a signal wire from an oil sensor.
Asking $75. That's $25 per gauge. which you wont find anywhere else. And this will just slip in your 944! remember kids, the more gauges your car has the faster it is!
SOLDSOLDOSLD
SOLDSOLDOSLD
Does it come with the oil temp sensor and for the AFR do you use the stock O2 sensor or does it come with a extra sensor for the gauge? Also do you have a picture of it installed?
Put me in line for it.
