Where's the low pressure port to recharge R134A?
Resistance is Futile
That's the rub, right there... it's a sanden 134 compressor with 134 in the system but the low pressure fitting isn't right, thus, my attempt to put a fitting on there... either that or I am completely missing something. Maybe it's a 134 conversion??? Hmm...
ahh... now i understand!
sorry, but only way to get the fitting on is to drain.
some people just use the high side to top off. not the right way, but might work for you.
If you need to do it high side you need an AC machine i believe. Thats how i do mine, and if your doing it with a can on the low side you need to start the car to draw the charge in.
Mark
Mark
Lazer Beam Shooter
Theyre standard fittings I guess and ours must be metric. If you replace the schrader valve to fit the fitting (otherwise they wont fit), they wont seal and will leak freon.
