WTB: Low Side R134a Valve for S2
The low side shrader valve is broken on my S2. I need to get good working one in order to get my a/c up and running. Anyone got an R134a low side valve lying around? This is the valve that goes on the compressor itself.
Threaded to install in the a/c compressor? If so then I'll drop on down to my local Autozone or O'Reillys. Thanks.
Does it matter whether it's a double or single valve? The one that is bad on mine supposedly had to valves in it but it was badly worn out and the cap broke off in one of the valves.
Resistance is Futile
To recharge it? You can buy a kit with a hose and pressure guage and 134 for 20 bucks...
If you are redoing your system, you need a vaccum puller...
