I have ball joint kit but, It will not compress
Old 06-11-2008, 12:19 AM
Travis - sflraver
Travis - sflraver's Avatar
A 2" piece of PVC pipe works well for the top (pin side) if you don't have a socket. Just cut it a bit longer than the pin.
Vice is good but C clamp works if you don't have one on the bench.
Make sure the retaining rings are seated completely. After you let off the pressure from the vice / c clamp / body weight / etc.. , TAP around the the ring with a screwdriver and light hammer. Just tap.. don't bang.
EDIT: added the PDF instructions to this post as an attachment.
Old 06-26-2008, 01:22 AM
Lizard944
Lizard944's Avatar
For future searchers, I bought this Ball Joint Press from Harbor Freight Tools. Worked like it was made to do 944 ball joints!! Child's-play. Also worked great on popping out ball joints from an Explorer control arms.
http://www.harborfreight.com/cpi/cta...emnumber=38335
Old 06-26-2008, 02:16 AM
Funn944
Funn944's Avatar
Harbor Freight, my favorite tool place. I did the rennbay joints on mine. Just take it easy, it will work. MAKE SURE THE RETAINING RINGS ARE FULLY SEATED IN THE GROOVE !!
Quick Reply: I have ball joint kit but, It will not compress
