How do you remove this hose?
I'm trying to install my Reliaboost, and I can visualize how it goes together and everything but I don't know how to disconnect the hose from the banjo bolt to the hard pipe. It's a clamp that looks like a Greek Omega. How do I loosen that so I can remove the hose?
Skwerl,
You will need to cut the fitting off. I used a dremel tool with a cut-off wheel. Inside is a normal tube with barbed end, over which you can slide on the new tubing, and secure with a clamp.
Ron
Ron
Okay, thanks.
