Need: Torque Tube Bearing Spacing Measurements
Those of you who have replaced the torque tube bearings, have you still got the measurements of how far each bearing fits inside the TT?
I presume that they are evenly spaced inside, but how far in is the first and last one (measurement 'X' & 'Y')?
TIA, Mike
TIA, Mike
On the first one I did the shaft had clearly defined marks where the bearings were. Thought the same would happen on this one, but no. When removing the shaft I moved some of the bearings and the shaft has no marks.
If someone who has a TT lying around could measure the distance in of both the bearings at either end, that would be fantastic.
