Does Your Cam Tower Whine?
Just a general question. Should I hear a whine from cam gear housing? It almost sounds more like a grind (yikes) than a typical whine you'd hear under the hood. I'm starting to wonder if it's the plastic dust cover behind the rotor. The sound increases with RPM and I've narrowed it down to the housing, so it's not rollers, etc.
Just a car guy
My girlfriend is looking to buy a 944 with a noisy cam/distributor. I'd like to see some feedback to the original question before we go and pick the car up.
The sound is very obvious at idle and at low revs. Once up to speed or while driving, sound seems to be less (or masked by other louder sounds).
Since I will be her tame Porsche mechanic - I'd like to get a headstart on diagnosing and repairing the problem. Any past experiences would be most helpful to at least two of us...
Just a car guy
Please expand...
The belt that makes the high pitch noise is the balance shaft belt...probably too tight or not adjusted correctly:
All you need to know about this stuff:
http://arnnworx.com/tensioningbelts.htm
If the chain was having problems you would hear it coming from the top of the vavle cover...this is not good ! I would put inspecting this higher than the belts, all the belts need is a quick going over.
http://boerger.golden-tech.com/image...eplacement.htm
DO NOT BUY THE CAR UNTIL YOU KNOW WHAT THE PROBLEM IS
Herr Unmöglich
Belts can make extra noise as well if they are too loose and hitting the idler pulleys.
My belts scream even after over a year, and repeated retensioning, no matter how loose or tight I make them.
