Track alignment settings?
Old May 5, 2002 | 11:18 AM
944Fest (aka Dan P)'s Avatar
944Fest (aka Dan P)
Unaffiliated
Question Track alignment settings?
Can anyone share with me some good alignment settings for a 951? I don't know why, but some folks treat these as a big secret. Also, what are the recommended street settings? What do you all run, trackside? I'll be on Hoosiers so I'll have about -3 Camber but I'm not sure where to go with the caster and toe.
Thanks much..
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Old May 6, 2002 | 01:22 AM
luckett's Avatar
luckett
From: San Francisco, CA Porsche: '92 968 Blk/Cashmere
Post
Since noone else is offering advice, I'll relay some setup info that has been recommended to me. I have no personal experience with this setup.
caster: max you can get out of it
rear toe: 0 to slight toe in of ~1/16"
front toe: 0 or slightly out for more aggresive turn in
Did you ask on the email list yet?
Old May 6, 2002 | 08:51 AM
Danno's Avatar
Danno
Post
Here's what I'm running in the <a href="http://www.opentrackchallenge" target="_blank">OTC</a> next week:
    Old May 6, 2002 | 09:42 AM
    eclou's Avatar
    eclou
    Post
    From what I have heard, people recommend
    Front:
    Caster- max
    Camber -one degree more minus camber than rear
    Toe- zero for tire wear, slightly positive for quicker turn-in
    Rear:
    Camber - as above
    Toe- slightly minus (toe in)
    Old May 6, 2002 | 01:11 PM
    eugene's Avatar
    eugene
    Post
    Front: Camber -3.5
    Caster Around 3.3-3.5
    (all I can get)
    Toe OUT 1/32 Total
    Rear: Camber -2.5
    Toe IN 1/32 Total
    Old May 6, 2002 | 02:47 PM
    GaryK's Avatar
    GaryK
    Post
    I just had my car set up. Difference being it's used for combined street and track, so I didn't go so radical on the camber. And I'll likely use Kumhos on the track, which don't require as much negative camber as Hoosier's. Settings were:
    Front:
    - 1 3/4 deg camber
    0 toe
    3 deg caster (max possible)
    Rear:
    - 1 1/4 deg camber
    0 toe
    And ride height level front/rear and left/right.
    Most importantly, all adjustments were done with me in the car and 1/2 tank fuel.
    Gary
    89 951
