1. Ground points. I know there are 2 on the bell housing/back of the block. are they the 90 degree bracket on one of the bell housing bolts and the smaller sized hole close to the torque tube?
2. wiring on the starter. From what i remember the positive battery wire goes to it (negative to grounding point) and then there is another wire that comes from over the top of the engine with a smaller blue wire as part of it. am i missing any and what connections do they attach to on the following picture.
3. I have found where every connector on the DME harness attaches except the one in the following picture. ideas?
4. These are the ends of the second wire that runs to the starter, and i completely forget where they went.
5. Last, these two are at the first split of the DME harness. I have one labeled as going to the block, and i have a picture that shows it attaching to the top of the bell housing, but i can't see the other one in the picture to see where it goes.
First off lemme tell you that I only really have experience on Turbo's so if any of this isn't pertinent, then I apologize.
On the starter, the larger wire hooks up to the point on the bottom of the solenoid where the nut is at the the top (on my car, two large wires were attached here). The smaller wire attaches to the small post right next to it.
The connector looks like an injector connector. I'm at a loss on this one.
The grounds that you have attach to the bell housing I believe:
thanks, that picture helps. I couldn't tell if they connected to the same place or different ones.
I really have no idea on that connector. I've looked at every piece that goes in that area and can't find a place for it that isn't claimed by another connector.
its not the throttle position sensor. That connector has 3 pins, this connector has 2. Also i have the TPS labeled. Somehow the label on this one fell off.
i don't think its that one either, if I'm thinking of the same thing. That one i also had labeled, and both the DME connector and the receiver on the block were blue plastic, not black.
I did solve number 4, those go to the back of the alternator. and Number 5 is all set, both of those are attached in their respective places.
You could take an ohmeter and probe between the connector and the DME connector, to see where and if it connects to the DME. Then lookup the DME pin number in the wiring diagram to see what it connects to.
