Cooling Fans
Cooling Fans
After changing my water pump and belts my radiator fans are not comming on. I will check the fan motors, the fuses, the relays, and the temp. switch tomorrow. Is there anything else to check? In a 84 944 NA where are the fuses and the relay for the cooling fans. Thanks to everyone who replyed to my question on bleeding the coolant system. I found that it was easy to jack up the driver's side and have gravity bleed the coolant and then finalize it with the car and heater running.
