reattaching rear glass
Does anyone have any instructions on how to reattach the glass in the rear hatch? Mine is coming loose and I need to fix it. Thanks
Bryan
86 951
Bryan
86 951
924 org has a bit on this, I tried it and it works as long as you do everything you are supposed to. <a href="http://www.924.org/techsection/technical.htm" target="_blank">http://www.924.org/techsection/technical.htm</a> , then click on the Bodywork section.
It is a pain to do so keep in mind that it may be easier for a glass shop to do it. It's easy to bend the frame and it's not easy to fix the frame once it's bent. Not all shops will do it, so it may take a bit of looking but they are out there. I heard it doesn't cost that much either. But make sure the shop has done it before.
I went to three different shops in my local area and none of them would fix this. <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" />
I think it is bcs of the cost of the glass if they break it.
