968 Injectors specs ?
If you are talking about the 968 injector Bosch #0-280-150-911, then they flow 33.5-lb/hr. The 951 injectors Bosch #0-280-150-803 flow 34.6-lb/hr.
These injector ratings are always quoted at 3-bar fuel-pressure and full 100% duty-cycle static flow rate. Some may be tested at different conditions such as 2.5-bar or 90% duty-cycle. But you can scale that back to the standard ratings easily (as long as they state the test conditions).
