Daughter wrecked her 89, what parts will fit?
I bent my frame and went to the body shop, they said over 5,000 to replace frame member and paint the part.
Thats with me, first, taking the engine out.(that would be an extra 1500 for them to do it) Now I look for a turbo instead of fixing my 944S
Well, from the picture there is allot of damage. Wheel, fender, lower nose, hood repair and then the suspension look to be all busted up. I hate to say it but sell the car unless you both love this specific car and money is not object then fix it. Just in body work alone I bet you pay 1K to get the parts either replaced or fixed. Then spend another 1K on the suspension and both quotes are without labor so unless you do the work so far you’re at 2k and I bet their were other things you both wanted done to that car before the wreck. Take it from someone that just and still is fixing up their 944na unless you love this particular car take the money and run to another great 944 on eBay that you can make better.
I pretty much have all the parts (less breaking my set of wheels for 1 replacement) for less than $500 if you decide to fix it. That pretty much includes strut, control arm, fender, front air dam, sway bar, etc. There is a little bending of the inner fender but I doubt the frame rail moved. I know I would be able to have that thing fixed and painted for around $1000 total including $500 in parts.
Well then, looks like your in the same boat I was, as for the frame there should be a shop that can knock that out for you and then with our help for parts and your effort you should be back on the road.
Good luck
Good luck
