It Shifts!
Just wanted to share my excitement. Finally got the shift linkage put back together and was able to run it through the gears for the first time (not driving, just sitting there). It does some weird thing where it sticks when you go to 5th, but i'm pretty sure its because the mounting bolt for that bar is worn down and hasn't been fixed on this car yet.
Feels good to be one step closer to running.
just final reassembly now. final belt tensioning, intake, vacuum lines, etc. then double check every bolt i've touched on the car. Hopefully it will turn on within the next week or two.
