What will I need to make these wheels fit my 86
Official Rennlist
Borat Impersonator
Borat Impersonator
wow. thats the stamped number on the tire.....LOL
If they came off a 99, then its should be like 55 front and 65 rear.
I actually have a set of spacers that should work for you. 30mm for the fronts and 50mm for the rears.
If they are OEM wheels the offset should be stamped by the valve stem
EDIT: I'm pretty sure those are Boxster twists, 17" which should have a 55mm offset front and 50mm offset rear.
I go out to Roselle often, so when you get the wheels maybe I can drop by and see if my spacers will work for you.
I ran those exact spacers with 55mm offset wheels front and back, so I know at least the 30mm will work but the 50mm might be too much spacer.
I bought a set off craig's list for less than $400 with tires. If you buy them, do not lay them on their front side to clean the back side. One re-paint later mine looked good again.
