Progress and questions VIII (ugh...not a good day)
"2. Does anybody know where I can find a diagram of the DME so I can find where to put the line from my air/fuel gauge into it to tap a voltage from the 02 sensor? I got double shielded probe wire to do this...I assume this will be good enough not to distort the signal."
"The signal from oxygen sensor comes in at Pin-24 and ground at Pin-28."
The line from the O2 sensor is a double-shielded coax cable so you can't just cut and splice into it like a normal wire. You'll have to disassemble the DME connector and solder your A/F gauge wire directly onto the connector pin. Not too difficult, just finely miniscule work:
