No start - what's next.
I need help. Have had intermittent starting issues with 86 951 since I purchased it. Orig. owner had the same issue - 1 reason he replaced car with new Cayman S. There was an intermittent connection on the relay board beneath the DME relay. (relay was replaced x2). I replaced the relay board, and problem seemed to be solved (at least 1 of them). I then had a failed starter obviously the car wouldn't start then. After new starter, I started the car 3 -4 times and drove about 30-40 miles over 2 days. On the next morning, I started car. Ran about 3 seconds and died. Good batter charge, "bouncing" tachometer (ref or speed sensor OK?) Good fuel pressure (used guage showing between 3-4 bar while cranking). What to check next? This problem has pushed me to consider selling - you may have seen DanP's post to XSBoosts' post last week. Gabe-I want to fix this before selling car. Any help would be appreciated.
Thanks,
Brad
Thanks,
Brad
Almost Addicted
Vacuum issue? I have had hoses spit off when the car died from running out of gas- maybe when your DME problems were happening it caused this to happen. Not sure about the 951, but on the NA there is a hose connection right under the j boot that has caused me problems.
I had a similar problem. Turned out to be a cracked solder joint in the DME. Took me a long time to find it, but I have not had a problem since.
Also, wiggle the speed/reference sensor connectors.......gently. These are prone to intermittant contact.
Buying a new Cayman S would also be a satisfactory repair.
