What size spacers???
Front or rear?
For reference, I have 17x9 993 wheeels on the rear of my 86 951 and I used a 28mm spacer. The front has 17x7.5 993's and I used a 21mm spacer. The 993 wheels have a 55mm offset front and rear. You will also need longer studs when you add the spacers.
On the rear of an '83, you'll need that 28mm spacer that Keith mentioned. But you'll need a 100mm stud instead. Parts list and procedure in the 944 Wheels FAQ section of my <a href="http://members.rennlist.com/951_racerx" target="_blank">951 RacerX website</a>.
A simple discussion on what kinds of forces are in a bolted assembly of parts: <a href="http://www.boltscience.com/pages/basics4.htm" target="_blank">Bolt Science</a>
