A Victory Over Fast Flashing Flashers!
Campeck Rulez
So after I installed trailer lights on the car, I had a fast flasher problem. So i went to auto zone and got a 3-prong trailer flasher without lamp outage indicator.
I put it in and since the Advance auto parts guy was admiring the car he commented that my headlights were flashing with the turn signals...At which point my wiring harness started to smolder!! OMG! Toggled off the car and put the original flasher back in except it didnt work any more and my right flashers where stuck on and my gauges were dead. No burnt fuses. greeeeeat
SO NOBODY PUT AFTER MARKET RELAYS IN THE CAR!!!! unless you are 100% positive they will work.
So after "supervising" my dad as he split open the wiring harness and replaced the smoldered wires I went on a search to cure the problem again.
I put in A flasher and started jumping points on it trying to disable the "fast flash"
All I did was fry the relay.
Then I opened up a tall one from a 944 S parts car. And I noticed a small POT on it. I turned it all the way down and now my flashers flash normally!
So If for any reason someone has a fast flash problem. here is a pic of unmodifiable solid state flashers and the one you can "tune"
Official Rennlist
Borat Impersonator
Borat Impersonator
wow I actually have this problem.
i'm gonna pop open my relay tomorrow.
All my turn signal bulbs are new and all work, and I have the fast flash all the time expect with hazards. Which way do I turn the thing? to the left?
Campeck Rulez
As you are looking at It right now It would go counter clock-wise for slower.
I bottomed it out and it matches up with my dads flasher.
