Intake manifold coming off, "while im in there" jobs?
As above, im planning on haivng the intake manifold off to replace the orings in the AOS, is there any other jobs anyone can recommend while im in there? Replacing hoses etc? Any advice on this would be great!
I'd suggest that you at least be prepared to replace hoses, or at least connectors, as I broke several during my disassembly.
Anyway, I'd suggest getting a wire brush and scrubbing the manifold and even the cam carrier with it. Getting rid of that goldish oxidation goes a long way towards making the engine look nicer.
BB.
BB.
pelicanparts.com i am going in there my self to fix the hose for the ISV and i will be replacing the intake gaskets and and also cleaning, adjusting, the ISV and removing as much crud as possilbe
Replacing every vacuum line and connector piece you can see wouldn't be a bad idea. Clean grounds at the back of the engine (one might be the bellhousing ground - they are about 2" apart). Engine temp sensor is under there too (NTC II), so check that. Throttle's pretty accessible on the S2, right?, so no need to rebuild that right now (not so for the S).
