Best Place for fuel pump?
Where is the best place to buy a fuel pump for my 1989 944 turbo. Can I get an aftermarket pump? Is there a better high performance pump for a stock motor? All help very appreciated.
Will
NPB, FL
Will
NPB, FL
Hey Man
For a high-volume aftermarket fuel pump you might also try the Walbro GSL 392. It is comparable to the high volume Bosch that sells for $340. The Walbro is less than $160 last I checked and is a direct swap using a 12mm adaptor on the inlet side.
http://pauertuning.com/
https://rennlist.com/forums/showthre...ight=fuel+pump
![](http://forums.rennlist.com/upload/walbro_fuel_pump_2_resize_copy2.jpg)
