83 944 at my local junkyard (Grabbed manual steering/manual roof for listers)
OT: my friend has an early 944 sitting in his backyard w/ no drivetrain, I'm already stealing a brake calliper, what are the telltale signs of a manual rack (it turns realll easy now cause there's no engine over the wheels!) They may have taken out the reservior too so that wouldn't be a giveaway.
The manual racks have a much smaller housing since they don't store a ton of fluid inside, have a much smaller 'head' on them where the shaft enters the rack, and have a big adjustment bolt on the front.
The power racks have a big fat middle section, and fluid lines coming off the back and down each side.
Very easy to tell the difference between the two
M
Under the Radar
If you end up with the phone dials and break up the set, I could take one of them.
My alignment shop tells me that one of mine is bent although I haven't been able to confirm this.
I assume the RH dash vent is toast but if not I would buy that from you also.
Thanks for saving parts!
