Removing auto rubber damper?
That rubber damper that is in the bellhousing for the automatic trans...
How the crap do I get it off the spline? Just pull it?
+1. Make sure the washer behind the snap ring goes back on the right way and sits in the groove. (Flat side facing front of car.)
Let me get the conversion parts ready after I finish the car I am currently working on. I should be ready by today. Let me know when you are ready. The only thing I don't have is a spring centered clutch disc if you are doing what I think you are doing.
I'm ready for the stuff whenever you are. But you don't need to rush. I just took the engine out because I have a timing belt breakage problem to fix
Also. I don't need a clutch i have one.
As for that snap ring. I cant get the thing out! It doesn't have any room to expand. It is crammed into a collar. Can I just destroy that damn ring somehow?! Or is there some trick to this snap ring?
