968 no start when cold
Old 03-02-2008 | 06:27 PM
bshaw's Avatar
bshaw
Default 968 no start when cold
We have an ongoing problem with my brother's '92 968 - it won't start when it real cold. It's flooding out, pulling the fuel pump fuse will get it to start and run until it's burned up the excess fuel. We can tow it and get it to start within a couple hundred yards, and once it's started and runs for about 30 seconds it will restart and run fine after that. We've replace the DME temp sensor with no change. Anybody seen this before?
Any input is appreciated.
Old 03-02-2008 | 08:06 PM
PorscheDude1's Avatar
PorscheDude1
On the Radar
How about the DME relay?
Old 03-03-2008 | 02:53 AM
FRporscheman's Avatar
FRporscheman
So it floods? Then you pull the pump fuse and it runs? That doesn't make any sense!
Find out if it's a spark problem or fuel problem. DME relays go bad a lot (never happened to me though). I've heard fuel pressure regulators can go bad where they work when hot but not when cold... and vice versa. I had it happen where it would start and run fine when cold but it sputtered when hot, and couldn't start. Maybe yours broke the other way.
Old 03-03-2008 | 05:37 AM
Jusii's Avatar
Jusii
I'd check FPR if it starts without fuel pump fuse. Usually when FPR goes bad, there's excessive fuel pressure, injectors will pull too much current and DME shuts them down.
Old 05-08-2008 | 04:23 PM
peanut's Avatar
peanut
good answer ! I'd go with that too.
did this problem get sorted in the end ? some closure on these non starting issues would be helpful to others facing the same problem
Quick Reply: 968 no start when cold
