stopping battery corrosion
Almost Addicted
So if I replace my battery cables, will that stop the corrosion? I'd hate to replace them and have the new cables do the same thing. It has gotten really out of hand lately- especially on the negative side.
Had that problem on one of the fork lifts here about a year ago. Switched out to some "gold plated" terminals made by DEKA. They seem to work well and I don't have the corrosion at the terminal any longer. I don't see why they wouldn't work for the 944 as well.
HERE
HERE
try these
These work well, are cheap, and you can get them at any Walmart
http://tinyurl.com/3cxokc
You'll need to clean everything up before putting them on though.
On my car the PO had some clear red spray on the terminals. Dunno what it is but I have zero corrosion on the terminals. it also has those pads from post #6. I think any auto parts should have this spray, I just haven't looked for it but may have to due to my battery getting weak, I think it's on its way out so, so when I replace it I should redo the coating.
Almost Addicted
Also, do I still need to swap the cables? I plan on doing it at some point soon, but I've got to get my front end damage and car painted first.
The lead seldom goes away. If the wire conductor is foul, then it would be warrant a cable replacement. If there's some slack in legth, you may be able to get by cutting them back to good wire and replacing the terminals.
Almost Addicted
Gotcha. So what is the best place to get a decent inexpensive neg cable?
