Parasitic Battery Drain Found! How to Fix?
Old Feb 5, 2008 | 06:15 PM
  #31
marky522's Avatar
marky522
Originally Posted by bearone
that pdf seems to refer to 911's and the 928 when done in sep '92, so what does "ALL" really mean?
87951
That post is still the rule for us, .30ma is the the spec for a draw on a fully loaded 08 cayenne. It applies to "ALL" vehicles in our line.
Mark
Old Feb 5, 2008 | 07:31 PM
  #32
ExitWound's Avatar
ExitWound
Originally Posted by marky522
Question, does your car have an alarm? If so, while your checking for the draw do you have the front hood latch tripped? do you have the door contact closed? just because you have the interior light fuse pulled with the door open doesnt mean that other things dont monitor door and hood switches.
My car is NOT equipped with an alarm, no. I also, a few months back, removed the aftermarket alarm the previous owner installed...partially. It was a mess, but I took out everything at the fusebox that was attached and discarded it all. Nothing is left of his alarm.
While I'm checking draw, the front hood is open (obviously) but the light does not function. We haven't yet figured out why. The doors are closed when I test as well. Everything is "off", the radio's faceplate is removed, the key is not in the ignition. The draw after removing the clock is ~60mA. If I was to remove the fuse from the amp-->battery constant power wire, it drops to ~49mA. The only other draw I could find is the central locking mechanism, which if removed, drops the drain to 50mA (radio still installed).
  #33
Got Me a Porsha's Avatar
Got Me a Porsha
Mark
First step would be for all of us to be on the same page with our values. While 30mA is quite small, .30mA (300 uA) would be negligible. Sorry to nitpic
Old Feb 5, 2008 | 07:37 PM
  #34
marky522's Avatar
marky522
Thanks, this post needed someone to lighten the mood remember i'm just a dumb tech...
Mark
Old Feb 5, 2008 | 09:04 PM
  #35
fastmover's Avatar
fastmover
then why did the draw remain the same 100ma after the changeout on the switch??
now the batt doesn't need to be charged every few days.
the car sat for 2 weeks and started this last sunday which again confirms,a 100ma draw is nothing.
fwiw:
i use a fluke 85 dvm in autoranging mode.
i mentioned not fully charging in post 25.
87951
Becuase the switch was not your problem, I cannot beleive the battery would stay good for two weeks with a 100 ma draw. Maybe you can recheck your draw at this time to see if has changed. You might have an intermittant draw.
On the pdf the term all means all Porsche vehicles. That bulletin apply's to the whole range of models, and has not been superseded yet. If specifications were to change for any models then the bulletin would be superseded to reflect those changes. The 30 ma specification is what Porsche deems acceptable limit. I will trust Porsche engineers for specifications. Porsche is not only a car builder, they also are a world leading engineering firm. I will take there guidance. This tech bulletin is also considered the standard in the Porsche service Dept. Fwiw I like to use the Snap on vantage pro, lab scope/digital graphing meter.
Semper fi
Old Feb 5, 2008 | 09:07 PM
  #36
fastmover's Avatar
fastmover
Mark
Don't worry Mark you are not alone!!
Semper Fi
Old Feb 5, 2008 | 09:40 PM
  #37
marky522's Avatar
marky522
Semper Fi
Tks for the reassuance i was getting lonely... Hope your feeling better.
Mark
Old Feb 6, 2008 | 12:16 PM
  #38
cubby944's Avatar
cubby944
EW,
If you are refering to the light inside the hood that does not activate unless you lift the turn signal stalk (ie right turn) in the ignition in the accesary position I believe. The only switch associated with the hood is one for the alarm. This confounded me for quite a while.
Good luck with the suck.
Old Feb 6, 2008 | 01:14 PM
  #39
bearone's Avatar
bearone
Veteran: Army
Cool
Semper fi
excuse me.
you tell me the switch wasn't the problem and i tell you when i replaced the switch i no longer needed to charge the battery every couple days.
the switch is the only component changed.
wouldn't the fuse ck, as mentioned in the pdf/clarks, have made a big drop when i got to the fuse that was powering the door switch when it was pulled, yet it never got below a 100ma and remained the same after changing the switch
which fuse powers the door switch, i don't see it listed?
i don't have the time to unhook the batt to check for you but will if i have any other batt issues.
from your own pdf: 25ma/5weeks
Old Feb 6, 2008 | 01:18 PM
  #40
marky522's Avatar
marky522
Obviously something else has changed since you did your door switch. If you had a 100ma draw before your replaced a switch and after you replaced the switch you didnt fix anything. Does your car have an alarm... Is it echoing in here.. I ask that already. If you have your door or hood open while testing your draw it will show nearly 100ma which will not go away because it is not fused in the panel.
Mark
Old Feb 6, 2008 | 01:21 PM
  #41
fastmover's Avatar
fastmover
If you want I will send you a copy of the wiring diagram and you can look it up. Just tell me the year of the vehicle.
All I am simply trying to say is, if you had a draw of 100ma and you replace the defective component that is conuming the power, the draw will drop. So by your statement 100 before and 100 after tells me you did not find the consumer, or your recorded results of your testing is off, or testing method/application is off, Something is not correct. That is all I am saying, don't take it personal, it is your car and your life, enjoy.
Semper fi
Old Feb 6, 2008 | 01:24 PM
  #42
bearone's Avatar
bearone
Veteran: Army
Mark
then what changed, only the switch was replaced. no alarm.
yeah i had the hood up doing the fuse check, do you know of another way to access the fuses.
door was closed.
87951
Old Feb 6, 2008 | 01:26 PM
  #43
bearone's Avatar
bearone
Veteran: Army
Semper fi
i tested/clarks, recorded everything, replaced the switch and haven't had to charge the batt since oct.
i didn't take it personally and i appreciate your input.
during this process i changed out/warrantied two batteries, thinking it was a defective battery.
the switch remedied the problem.
87951
Old Apr 17, 2020 | 04:36 PM
  #44
bullz56's Avatar
bullz56
Am I just lucky or did I just find my parasitic drain by pulling the battery fuse from the fuse box? It must be the cable ?
Old Apr 17, 2020 | 05:17 PM
  #45
bearone's Avatar
bearone
Veteran: Army
yes, you can stop the drain but you haven't fixed the problem.
