Great Suspension Mod for $40
Old 02-13-2008, 10:01 PM
Keithr726
Keithr726's Avatar
Is there a good tip for getting the bolts out of the cross member? I've done everything just can't get these frickin things loose. It seems like my socket will break before they come out.
Old 02-13-2008, 10:08 PM
Techno Duck
Techno Duck's Avatar
More leverage and a 6pt socket. Had some trouble with mine also, but nothing a breaker bar and some brute force couldnt handle.
Old 02-13-2008, 10:39 PM
RedlineMan
RedlineMan's Avatar
Pfffff....
The ones I make are easy to get in. I've never had any difficulty with them at all, and no one that has bought them has ever complained. The trick is to have all pertinent fastener loose until all of them are in place, and only tighten ANY of them when they are all in.
Piece of cake. I'd be VERY surprised if you noticed a difference in handling, but it is certainly nice not to have the bar fall off in the middle of a corner when the OE drop bracket snaps. Tends to mess up the chassis balance all of a sudden. That HAS happened. I've seen the result, and it aint pretty.
Old 02-13-2008, 11:03 PM
Z-man
Z-man's Avatar
That's on my <short> list of things to upgrade before the season starts! I agree with Redlineman -- probably won't notice a difference in the stiffness, but will definately give me peace of mind.... I have also seen the stock drop brackets snap... happened to me coming out of the Boot at The Glen (T9, IIRC). Car went from neutral handling to "gee - I suppose that's what a 911 feels like when the rear breaks loose" in a split second.
-Z
Old 02-13-2008, 11:33 PM
Travis - sflraver
Travis - sflraver's Avatar
Originally Posted by BeerBurner
Hmm... let's see if I can remember it... I think it started with "stupid f*cking g*dd*mn piece of sh*t..."
Yep, same problems here. That's why I made ours like this. If you have ever put a set in there is no explanation necessary.
Old 02-13-2008, 11:46 PM
FRporscheman
FRporscheman's Avatar
Originally Posted by Techno Duck
Another reason these are good is they help prevent the drop links from breaking. Also i have seen some track cars (mainly those running wide rubber and big sways) in the front actually have cracks around the frame rail where the droplink attaches. I think by triangulating the mount you help reduce the occurance of this happening.
This happened to our 944, and it hence has been without a front sway bar for months. It's strictly a street car.
Old 02-14-2008, 12:13 AM
Lord_Galva
Lord_Galva's Avatar
Pardon me captain, but not installing "swaybars" would compromize the structural integrity of the "suspention."
Old 02-14-2008, 12:20 AM
959Lover
959Lover's Avatar
Old 02-14-2008, 12:24 AM
knfeparty
knfeparty's Avatar
travis, does the bracket go in between the washer and the crossmember, or the bolt and the washer? or does it replace the washer?
Old 02-14-2008, 12:26 AM
yellowline
Under the Radar
yellowline's Avatar
Will these work on an early car? The brackets on my 83 look the same as my 944S.
I have a few maintenance items to buy at this point, but I'll put it on the wish list.
Old 02-14-2008, 12:30 AM
FRporscheman
Yeah, they will work on early cars.
Old 02-14-2008, 12:47 AM
Keithr726
Keithr726's Avatar
God them loose, had to use a larger socket wrench for leverage. Now how do I put a new bushing in the outer bushing clamp?
Old 02-14-2008, 01:06 AM
944obscene
944obscene's Avatar
This almost qualifies as maintenance. I would do this first thing since its so cheap.
Old 02-14-2008, 07:37 AM
BeerBurner
Unbannable
BeerBurner's Avatar
I agree with the "no explanation necessary" portion of this quote.
BB.
Old 02-14-2008, 08:47 AM
Techno Duck
Soapy water and a vice.
Quick Reply: Great Suspension Mod for $40
