HELP MY 944 WONT STOP FLOODING!
It's rainy season up here in Northcal and My passenger side floor is ALWAYS wet, i thought i fixed the problem by coating AND testing the battery tray ( that is fine ) and the window seals ( no water getting in through here ).. its not from the heating system either, its definatly water. SO where do I check next?!, i don't have a garage out here and my cars interior is going to be horrible if this keeps up. Any suggestions!?
thanks,
-Tyler
thanks,
-Tyler
I had this same problem with my old 944, and with our current 944. I too tried the battery tray fix, and I tried cleaning the sunroof drains. I couldn't pinpoint it. I was going to start trouble shooting it with a little blunt force. I was going to put a fat strip of duct tape over the rear hatch upper edge. If that doesn't stop it, I was going to tape the sunroof borders. If that doesn't work I was going to put tape over the windshield seal.
The best way to diagnose a leak is to strip the interior and get inside the car, and spot where the water is dribbling in from. I did this in my old benz, and it worked. Except the carpets in a benz are not glued in, they are just mats placed in, so it was easy to strip everything out.
Go buy yourself a rainproof car cover for $75 at Kragen.
Yeah, mine leaks if it sits in the rain, but not really if you drive in the rain. It leaks around the sunroof, even though I verified that the drains work fine. Now I just cover it up and it doesn't give me problems now!
Believe me, the car cover is definitely the best solution.
944s seem to be prone to leaks but I eventually fixed all my leaks after 2 winters of sever flooding lol.
my rear seats were getting wet ended up being the quarter window seals leaking.
passenger compartment was wet same with rear footwell, I tought it was the battery tray, sunroof but it ended up being the heater fan assembly but this is an 85.5 model. I had to reseal the heater fan.
no more leaks now.
no more leaks now.
I had to remove my entire interior and clean it all up, my car smelled like a moldy sponge until I fixed the leaks and cleaned it real good. I actually had green mold growing on the rear seats..... really gross.
replace back lights seals. if they leak you get water all over the place.
A leaking heater fan? Good catch! I'm gonna go check my 944's heater fan because it leaks pretty bad too.
But the best quick fix is a car cover.
I have the TSB for possible water entry points. A few odd places it lists are: spot weld at door hinge pillar to wheel house, triangle intersection of the windshield frame-water drain tray-wheel house, front sunroof drain tubes can be punctured by the trim panel mounting screws, corner area of water drain tray & front engine wall, central electric board mounting plate, spot weld points for the foot pedal support, spot welds for battery mounting bracket.
For an update, I pulled teh carpet out a bit from the spot where the pop hatch button is but passenger side. There is definatly some moisture in there, I think i have it narrowed it down to the windshield seals (It has been replaced in the past).. or the Sunroof drains. Good thing I have a garage where I'm moving in a few weeks
