944S2... more power?
#31
The best power modes to S2 will be to make sure it still has the original power. For a nearly 20 year old car is easy to loose 50bhp. This is why you see some S2 feel much faster then others. Before trying to get the additional 10-15 that you could get make sure you have a fast S2 already. Usually what will restore most of the power back is a good head job.
Hello Maki
I m from Hellas Thessaloniki
Could you please make the effort to write the upgrade in Greek language because I do not understand and any try for translation was not helpful at all.
Thank you in advance
Regards
Evripidis Arslanoglou
#32
S Exhaust Camshaft swap for S2
Well looking at the cam data it looks like the S2 CAMS have higher duration and more overlap then the S CAMS. So this suggest to me that the S CAMS will produce less power then S2 CAM in the 3.0 engine, but should produce better torque at low rpm. So unless the S CAMS are higher lift they are unlikely to give the extra power according to this figures.
944S Exhaust Cam
Duration: 212 deg.
Lift: .395" (measured)
Lobe Center: 110 deg BTDC
944 S2 Exhaust Cam
Duration: 212 deg.
Lift: .385" (measured)
Lobe Center: 113 deg. BTDC
Conclusions: Is the S exhaust cam significantly different from the S2 cam? Yes. It has more lift, it has more retarded exhaust timing, and therefore more overlap. The S2 engine likes it. Jet951 has proven it on the dyno, my own experience has been similar, and the Firehawk guys experienced a significant increase.
All of this said, the WebCam offerings will provide even more power, but ECU tuning will be necessary.
MM
