Tire trailer
Tire trailer
While poking around, I found this article....pretty good so I thought I'd share...even though it's a Miata it could easily be a 944.
enjoy!
http://www.mainstreet-data.com/trailer/
enjoy!
Wouldn't even know it's there if it weren't for the awful racket it makes whenever you hit bumps. Just want to make sure everything is strapped down tight as the trailer is so light it'll bounce pretty good (on larger bumps I've seen it get nearly 6-8" of air).
Hitch weight is maybe 20-30lbs... can carry with one hand no problem, and the whole thing is light enough you can move it around without much fanfare.
It's really nice having everything nicely packaged so that I don't have to pack/unpack before & after each event. I also can carry a lot more 'little' equipment as I don't have to worry about the hassle of moving it around. Plus... it leaves the trunk 100% empty for things like suitcases & tents for longer hauls.
