Waterpump Woes..
Waterpump Woes..
I have a small to moderate coolant leak coming from waterpump area, however, I will likely be unable to take a closer look for a couple of weeks. My hope is that it's a hose or something simple, because the current waterpump only has about 35k on it, and it's an OEM, not a rebuild.
Anyways, my question is whether or not it is safe to drive, assuming that I pay close attention to the temperature guage, can anything else go wrong? I know that the leak will probably get worse, but as long as I do not let it overheat, by either adding coolant, or letting it sit, I should be fine, right? I have about an hour drive back to school coming up this Sunday. I would like to be able to get the car to school, at which point I'll let it sit for a couple weeks until I can get to my buddies nearby garage.
If strongly advised, I can leave the car at home, but that means that I won't be able to get to it for at least a couple months...and that's no fun. (BTW, car is a '91 S2)
Thanks in advance for any advise.
