OEM 7x17, 9x17 996 wheels on 924S?
Old 01-05-2008 | 01:40 AM
jbob's Avatar
jbob
Default OEM 7x17, 9x17 996 wheels on 924S?
would these work on my 924S
also, i keep hearing about late and early offset. for the record, what am i dealing with..
OEM Porsche 996 wheels, as installed on cars from 1999 to 2001. Fronts are 7x17, ET55, p/n 996.362.124.00 Rears are 9x17, ET55, p/n 996.362.128.00 These will fit most late-model 911s ('90-on), 944s ('87-on), 968s, and possibly Boxters as well.
thanks
Old 01-05-2008 | 02:13 AM
Pcar944's Avatar
Pcar944
I was tempted by these:
http://seattle.craigslist.org/see/pts/523638680.html
Old 01-05-2008 | 05:12 AM
Erzengal's Avatar
Erzengal
Originally Posted by Pcar944
Too much for a 16". You can get a decent set of Turbo Look Twists for that price. Also, 50% tread left = needs new tires.
Also, wtf does this mean?
5 WHEELS ONE IN BOX
Back to topic on hand...
924 with 18's
Although I am unsure of the differences since your offset may be different then his.
I''d say try to go with something around 16x7, however you can go larger if needed.
Old 01-05-2008 | 03:59 PM
Tim Comeau's Avatar
Tim Comeau
The 924S came with ABS offset 6 inch wheels. The offset is 52.3mm. This is because of the narrow bodywork.
I think that 17's would look pretty pimpish.....
Not to mention most likely double the cost of your rubber?
You can put a 7 inch late offset wheel under the fender of a 924S if you switch to smaller diameter front springs. I used to race a 924S in the 944 spec class with late offset 944 phonies and a 15mm spacer, but the only reason the spacer fit was because I was running 3 degrees of negative camber. So the tire just barely cleared the fender lip during suspension travel.
Quick Reply: OEM 7x17, 9x17 996 wheels on 924S?
