Fuel Line Inspection
I have an 87 944na and after spending some time under the hood and under the chassis I've been noticing much of the fuel lines have a sort of chalky white covering.
I am new to these 944's but as I understand it, it's not uncommon for them to go up in flames due to leaky fuel lines. What should I do about my lines? I haven't noticed any leaks yet. I head something about treating them with some sort of oil to keep them good- or should I just keep an eye on them?
All comments/input is appreciated. Thanks!
The hard metal lines, you need not worry (that white chalk is most likely salt from the roads or light oxidation). I recommend everyone replace their soft lines, however. Inside their coverings the lines harden and eventually crack (after 20 years of deterioration). Just my opinion, but I like to play it safe.
Best Regards,
Benjamin Goldstein
Best Regards,
Benjamin Goldstein
