H&R spring set for 944 s2 cab
My 944 wears a suspension coctail made by my ex mechanick.Bilstein at the front with lowering springs and konis at the back with stock torsion bar.The car turns fantastically But the front springs are off.Should i install 200 or 250 lb springs?I bet you have questions about the coctail.The concept was hard suspension at the front because of the weight of the engine and soft at the rear.you can t imagine how well they worked together Just for the record the bilsteins were inserted in the front original struts in a workshop
