'84 NA 944 odometer repair
http://www.pelicanparts.com/techarti...uge_repair.htm
If people talk about buying a new odometer gear, they're talking about the late speedo. The early speedo is quite different, and the gear on these doesn't break. A different gear comes loose and needs to be loctited. There can sometimes also be a problem with the odo shaft migrating into the wrong position, and you gotta get creative to fix that.
