R-134a versus R-12
Old 12-03-2007 | 03:28 PM
S2cab's Avatar
S2cab
Originally Posted by Mike C.
I've topped off using Freeze-12 on a 90 Miata with no problems (mixing R-12 with Freeze-12).
I thought Freeze 12 was 80% R134a? If so, wouldn't that be bad for the R12 seals?
Old 12-03-2007 | 03:49 PM
Mike C.'s Avatar
Mike C.
It claims to be compatible with R12 although it is 80% R134a. The Miata still does have a leak but I really don't know if it leaks any faster with the R12/Freeze12 combination. Topping off at the start of the summer season lasts for the whole summer though.
Old 12-03-2007 | 04:50 PM
Moe's Avatar
Moe
Freeze 12 is 134a, it just has compatable R-12 oil...
Last year I needed a weeks worth of Cold Air in the 968, and had a can of Enviro-Safe... I know the Compressor is leaking so without pulling a vacuum, I loaded the Enviro-Safe for the hellof it ... Nice and cold for a week... No fire... But this year I'm gonna replace the compressor and drier and clean everything, to convert to 134a...
Old 12-03-2007 | 06:18 PM
Darwantae951's Avatar
Darwantae951
My dad just recharged his 911 with duracool. He is pretty happy with it so far. (I can't access the site right now but I think it will directly replace both R12 and R134A)
-Darwin
Old 12-03-2007 | 11:11 PM
Mike C.'s Avatar
Mike C.
The EPA says Freeze 12 is 80% R134a and 20% R142b, the 142b is an HCFC (Hydrochlorofluorocarbon - a compound consisting of hydrogen, chlorine, fluorine, and carbon)
Old 12-05-2007 | 05:38 PM
Shabba's Avatar
Shabba
I had my '88 recharged with R12 this past summer and it would put icicles on my beard. My '83 I used to have had been converted but retained the old dryer and expansion valve...it worked but not nearly as well as the '88 has. I'm not sure the systess are identical in the cars what with the 5 years difference, but that's just my .02 on the subject...
