Manual sunroof conversion?
Latches are all you need. It took me a while to find latches but they are popping up left and right on ebay now that I don't need them. s/b 50-60$
Use the same recievers that are there but I think I had to remove the lifting arm assembly. So I removed everything else while I was there.
And you use the same sunroof and liner. You can cut out the liner so the latch fits 'flusher' (more flush?) which I will probably do next.
