does a 944 turbo have a "ignition control unit"
11-23-2007, 08:45 PM
1986 porsche turbo 944
wont start
i am able to pop the clutch and it runs fine
starter was tested and is fine
i was told it is a bad "ignition control unit"
the "ICU" is not even mentioned in the haynes manual
I think its a 944S only part
any idea where it "should" be located?
thanks
11-23-2007, 08:52 PM
Would help to know what you are loosing when it wont start. Fuel or spark? and what does it do when it wont start?
11-23-2007, 09:53 PM
Only the 944S and S2 were the only cars that used the ICU. Interestingly enough the 968 3.0L didnt use it either.
11-24-2007, 11:45 AM
Quote:
Originally Posted by
SpideySlave944
What he said...
Cars that ran ignition control units can't be push started if it's an ignition issue.
If you are push starting the car, sounds to me like you have a starter problem?
11-24-2007, 02:12 PM
If it wont crank when you turn the key, but you can push start it sounds like a bad clutch safety switch.
Mark
11-24-2007, 02:50 PM
marky522
Mark
There is no clutch safety switch on any 944.
11-24-2007, 05:52 PM
That might be the funniest smiley face I have ever seen.
11-24-2007, 06:00 PM
Sorry, I work on 997 everyday so im constantly thinking 997... My bad...
Mark
1986 ,
944 ,
bad ,
control ,
find ,
ignition ,
location ,
porsche ,
push ,
start ,
support ,
switch ,
turbo ,
unit ,
wont
